Dana 60 tie rod
Discussion in 'The Garage' started by dodgedude99, Jul 4, 2005.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    before anyone goes and says "use the search" i did, when thru about 10 pages and gave up.
    i need to have a piece of dom cut and threaded and found a local guy to do it cheap.
    the problem is i dont know what the dimensions would be if i used the TRE's ES2234R & ES2010L.
    can some shed some light on the correct length, or tell me how to do it.
    thanks
    shawn
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    install just the TRE's on the D60
    measure from the middle of the threads to the middle of the other. That will give you some adjustment in them if need be.
  3. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Center of tie rod hole to center of tie rod hole, then deduct 4 inches. That allows room for the jamb nut and some adjustment.
  4. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    thank you for the help.
