Dana 60 time...
Discussion in 'Rocky Mountain Region' started by az-k5, Feb 18, 2004.
  1. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Well I finally gave into temptation. I was at marvs last friday and said I wanted to buy his dodge D60, and the funny part is he wanted to sell it. So now the fun begins. I want to find a couple of local favors if at all possible. I want to find a 1310 yoke and a stock arm (hopefully with a block). The arm will be temporary 'till I can afford x-over.
    Any help along with ideas on parts or modifications will be appreciated.
    PS. I already have a buyer for both of my D44's so no vulturing. /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
    /forums/images/graemlins/woot.gif <-- the "I GOT A 60" dance. sorry couldn't help it /forums/images/graemlins/pimp1.gif
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've got a 1310 yoke, at least I think I still have it, if I can find it. I've also got a stock steering arm you can have if you can find me a stock tin cap (like goes on the passenger side).
  3. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    I heard, congradulation /forums/images/graemlins/waytogo.gif!! You still need to find the thing call flex though.... /forums/images/graemlins/histerical.gifHA!!
    Going to miss you in Cruces..
    Rob
  4. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    Not to hijack, but I'm buy the Dana 70 out of the rear of the Dodge and need a yoke for the Dana 70 to goto 1350 u-jiont. Anyone got ideas as to where to get one cheap? Cause the Detroit Locker /forums/images/graemlins/woot.giffor the Dana 70 is costing more than the front and the rear axles toghether /forums/images/graemlins/yikes.gif
  5. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Russ I will see if I can dig one up, will a ford D60 be the same?
    Rob I figure the flex issue is like this, us younger guys are just more flexible ourselves than our trucks, you older guys aren't as flexible but make up for it in your trucks so when I am about 29 I should be in a happy medium. /forums/images/graemlins/rotfl.gif
  6. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Jay, find a GM 70, used they cost as little as $40 (whole thing).
  7. Jays Beast
    Aug 7, 2002
    538
    Chandler, AZ
    Yeah need to start looking for one what years did GM use the 70. Also did you see in the for sale forum the propane setup for sell.
  8. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    GM used a 70?/forums/images/graemlins/confused.gif.....
    Shows you what I know...
    /forums/images/graemlins/peace.gif D44 till I die! /forums/images/graemlins/doah.gif
    Marv
  9. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Jay,
    clicky...
    I already sent you a PM with the same link. /forums/images/graemlins/waytogo.gif
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    78-79 is the only year for the Ford king pins, but any king pin top hat should do...
    Marv and Jay, GM used D70s in (most?) all dual wheel 1 tons.
  11. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    matt I have a stock arm draglink ectand pitman arm with your name on it,,free /forums/images/graemlins/thumb.gif
  12. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    /forums/images/graemlins/crazy.gif.... didn't they also use 14b's? I have a dual wheel 14 in the backyard. ... i think/forums/images/graemlins/thinking.gif
    Marv
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Sorry, miss-spoke. "Dually" trucks had D70 (thought I've heard claims of C14FF in dually trucks, I'm not convinced). "Dual wheel" chassis cabs had C14FFs...
  14. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    PM or2play, he has a stock arm for sale.
    Grant
  15. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    You're right Russ /forums/images/graemlins/bow.gif.
    I too have yet to see a 14FF under a DRW p/u. Seen lots under cab/chassis (D70's too), but not under a p/u. It was a track width issue I was told. There were three or four widths (including the DRW p/u width) available. I didn't realize this until I started doing some research on a DRW conversion a few, uh, several years ago. At this point, those memory cells have some surface rust on them so I'm not exactly sure of the total amount of widths available, but I know there was at least three, possibly four.
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I got a correction from my buddy Matt (NoRulz).
    77.5-79, & 85-91 are kingpin (80-84 1tons were TTB )
    the 85-91 had a wider frame & the short side tube is only about 6" between the housing & the inner "C" though... nasty offset that's hard to use without retubing so it's alot less popular.
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Apparently Parts Mike has the little top hats for $8, so that would be one cheap option for a steering arm. I just need something to close the king pin if I take mine off. But sounds like you have another anyway...
  18. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I'll call mike and trade you just the same. Do you have a 1310 yoke still (I have one on its way but want a spare).
    Thanx.
  19. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'll have to take a look, it should still be out there in that mess I call a shop...
