dana 60 trac lok any good?
Discussion in 'The Garage' started by sweetk30, Jan 17, 2005.
  1. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    are the trac loks for a 60 any good ?:thinking: or should i just be a good little boy and get a locker for the frt ?:ears: thanks for any info:cool1:
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    It all depends on how/what kind of wheeling you do .
    A T/L WILL one wheel on you in a hurry - that being said if your off-road is mild sand , and/or slick mud than it will do fairly well . If you are going in the rocks ( or anything close to that type of wheeling ) than forget it .
    Once a T/L starts to one wheel it will never be as aggressive agin until you install new clutches and friction disc's . T/L's are ment to be a VERY mild traction diff - they were not intended to for moderate usage.
    HTH's , Tom
  3. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    i'd get a locker
    My dana 60 had one in it when I got it and I was unsure about keeping it or going to a locker before I got it in the truck. I tested it by putting the truck in front wheel drive only and locking only one hub - it did not hold good enough to move the truck on level ground so I got a locker.
    Just my 2 cents.
  4. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Excellent example. :thinking:
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Trash locks are just that.....:grin:
  6. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Pretty much! Got one in my front end, it's pretty much an open diff now, there isn't much trac or lock left in her. If you got it free, it might be worth trying but anything other than slick mud will bias the tire with traction.....Good luck..
  7. sweetk30
    Nov 1, 2004
    25,552
    545
    thanks for the info
    so thay are no good for longevity and thay are closly related to the GOV BOMS thanks for the info guys:cool1:
