Dana 60 trac-lok?????
Discussion in 'The Garage' started by BLZN4FN, Mar 7, 2006.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Ok I found a Dana 60 trac-lok on e-bay. It"s for a 3.08 to 4.10 without spacer and fits 4.56 to 6.17 with a ring gear spacer. Trac-locs web site states no ring and pionion set up needed with this locker.
    My question is. I have 4.56 gears so I will need a spacer. Where do i find a ring gear spacer? And if I do will I have to setup my gears?
    Let me know what you think on this if this is a good way to go or not:confused:
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    most are 30 spline
    need to find 35 spline side gears from dana 70 trac lok to make it work up front. if thats what you are doing.
    *shouldnt* have to change pinion depth, only backlash.
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    IIRC D70 trac-loks are fairly rare...unless power-lok stuff interchanges too.
    You're almost better off waiting and trying to get one out of a CUCV axle. (35 spline) If I weren't welding mine into a ball I'd send you the carrier.
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    D70 T/L's are so rare to the point that they do not exist ....... The only O.E.M. clutch typr diff for a D70 ,from Spicer/Dana, is a P/L.
    As stated up above anytime you cahnge the carrier you will need to adjust/check the side to side clearances.
    HTH's Tom
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    It's alright, t/l's aren't worth a sh!t unless they're welded solid anyways.
  6. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Give me the 60 Bo and find a cheaper way???:D
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    As far as I know there were Trac-loks made/used in front 60's, but not that common.
    I don't know how you could replace an open diff with a Trac-lock and not reset the gears??? You might get lucky and be able to reuse the same shims, but I would at least double-check them. Are you sure you are looking at the correct website??
    In general Trac-loks were a fairly mild/weak limited slip (meaning they will not keep both tires spinning) that was made so OEM's could offer a little more traction but not really effect the handling or driveability. If you have both tires sitting on level wet grass it will work, but don't expect much more. I personally would not bother to spend the time installing one even if I got it free.
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The jeepers that wheel with me call them "trash locks"...I wonder why?;)
  9. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    Theres no way it can be for 3.08 to 4.10. Maybe like 3.54 to 4.10. the 3.08 would be a dana 61 and would need something totally different.
    BTW you would need a 904a spacer from mr. gasket if thats the way your going.
  10. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I have a Tracklok for 4.56 and up gears, 35 spline. I never used it, got it off a guy on Pirate who had it in his crawler, wanted something stronger in the front, IIRC he went to a spool. I paid $150+plus shipping, do the same for you. And if the ebay add says it's for 3.08-4.10s, it's a Dana 61, NOT a Dana 60. Lowest you can go with a D60 is 3.31s. The only trucks that came with T/L in them is the CUCV, and a year or two with Ford. And you can't take the sidegears from a D70 T/L cause they don't exist, and the P/L gears are different. If you have a T/L with 30 sp and want to go 35, then you will have to hunt down a set from somewhere, Dana doesnt' carry them anymore. Now if you have a D60 P/L with 30 sp, then you can take the gears from a D70 P/L to use in a front.
  11. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I vote skip it and what for somthing else better.
  12. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I should have been more specific before, I roasted mine completely in 2 runs and it wasn't worth a damn beforehand anyways...don't get one.
