Dana 60 ubolts?
Discussion in 'The Garage' started by JUNIOR-K5, Dec 27, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    I just installed my dana 60 on my sub. today and the the two bolt that bolt on to the pumpkin are to long. I got the ubolt kit through superlift and Im running kerts spring plates. The studs are threaded on both ends and are about a inch to long. Threads are not long enough to tighten up can I use two bolts instead. Thanks.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, go to your local hardware store and get new grade 8 bolts to the required length you need.
  3. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    Cool thanks.
  4. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    stock bolts i remove all the time are grd 5 bolts.
