Dana 60 vs. 14 bolt ff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Nov 20, 2001.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i';m thinking of running 44s later on down the road. from what i can gather the 14 bolts can only go to 5.13's. where as a dana 60 can go to 7.17's. is this correct for front and rear D60s?
  2. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    if you want to go with lower gears than 5.13, and your gonna run 44s, forget the 60 and just go with a 70. you can get ultra low gears for one and it is just as strong as a ff 14 bolt.
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Front and rear D60s use the same r/p as far as I know. Never fooled with a rear D60. With 44s I would also suggest a D70. Also, most D60 rears will have the low spline (14? not sure but weak) axles. I know that it is possible to upgrade the rear but I don't know what is required (hmm, swap a high spline count front carrier with custom axles?). D70 is just as strong as a C14 but with better gear selection. A D70 usually has to be cut down from a dually although they can sometimes be found the right width (or close enough) from Vans etc. C14 benefit is cheap, common, and easy locker install.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    14ff with 5:13's and a doubler t case and you have the best of both worlds.[​IMG] Hell Watson runs 42's with 5:13's and you know he uses it for hardcore stuff.[​IMG]
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i am leaning towrads the 14. manly because i have one. it just need a compleate rebuild.
  6. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i am leaning towrads the 14. manly because i have one. it just need a compleate rebuild. i'm looking to run the NV4500 and the doubler set up. so i can have the 7.17's and still drive on the free way.
  7. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
    One thing you should also be aware of when going really low is strength. You loose strength the lower the gears you go. If you were to look at the pinion from a dana 60 in say,
    3.73, 4.10, 4.56, 5.13, 5.86, 6.17 etc etc, you would most certainly choose the 3.73. The reason is because the pinion size greatly decrease the lower of gears you go. a 3.73 has a monster pinion that would be hard to break, a 5.13 set has a pinion about the diameter of a soda pop can, and it only gets worse from there, not to mention the heating problem associated with a pinion that small. My friend with 6.17s went through both front and rear pinions every few hundred miles, he had a lot of power and was turning big tires. Every time he serviced his diff, pinion teeth were in the bottom of the housing. Just something to think about.
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    There are lots of reasons you don't see big tire 4x4's driving down the road(big as in 40" +)
    Think about it !
  9. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    HA[​IMG] me think. lol thats a good one.[​IMG]
  10. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    oh i completly forgot about that.
  11. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    d70s came in late 80s early 90s 3/4 ton dodges
  12. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    My and my friend found a Dana 70 HD out of a 98 Dodge 3/4 ton Diesel. It fit under his 87 Bronco without a problem. We had to move the shock mounts and spring perches, but the width was PERFECT. It's now re-geared 4.88 with an ARB on 42" TSL Swampers. Runs great and is unbreakable. There were several Dana 70's, so lockers are different. This one was an HD which has a little more metal on the case.
    Red 1989 GMC Suburban SLE V1500 - TBI 350, 700R4 w/ shift kit, Quad-shock front, 31/10.50/15 Pro Comp MT, 4.10 gears, Duals off cat
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Doh! I knew that. I guess I just had my GM tunnel vision getting out of hand. [​IMG] Thanks for the wake up!
    Russ
