Dana 60 vs. 14BFF???
Discussion in 'The Garage' started by OffRoader93, Sep 29, 2003.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    How much strength difference is between a Dana 60 and a 14BFF? Thanks.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I asumme you are talking about a rear 60. there is a big difference, like one, some 60's are SF's and all 60's only have a 9&3/4 ring gear compared to the 14's 10.50. The axle tubes and axles are bigger on a 14FF. The only benifet of a rear 60 is there is more aftermarket lockers available and lower than 5.13's can be installed. As far as strength, 14FF!
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is a significant difference between a D60 and a 14 bolt full floater, the 14 bolt being quite a bit stronger. A 14 bolt FF is comparable to a Dana 70, where the 14 bolt semi floater would be similar to a rear Dana 60 in size.
