Dana 60 vs. Dana 60 High Pinion......dimensions?
Discussion in 'The Garage' started by Greg72, Feb 4, 2004.
  1. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Does anyone know what the difference in pinion height is between the standard D60 and a high pinion D60?
    I'll take the measurement any way you have it, as a centerline-to-centerline difference (inches), or somehow referenced as a distance from the top of the axletube??, etc.
    /forums/images/graemlins/thinking.gif
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Greg,
    PM a guy named "hipinion" he has a brand new boyce equipment HP D60 in his garage awaiting install. I'm sure he would be more than happy to take a measurement for you. /forums/images/graemlins/waytogo.gif
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I am going by memeory but I think it is 3-1/8" from center line in each case . I can verify this later if no one else knows for sure .
    Tom
  4. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I believe that 3" is real close. I would need to measure mine to be sure and it is snowing at the moment. Also, keep in mind pinion angle as this can help a lot if you are building a unit.
    Mike
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Greg, I've got my Dynatrac catalog here and it shows the centerline of the pinion in accordance to the centerline of the axle shaft or tube for the high pinion at 1 1/8" ABOVE where the standard D60 would be 1 1/8" BELOW the axle shaft centerline.
  6. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Wes is correct - my books show the same distance . The older I get the worse my memory gets . /forums/images/graemlins/eek.gif
    Tom
  7. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Wes,
    So am I understanding your description right......the centerline to centerline difference for the pinion inputs is 2 1/4"???
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, between the standard and reverse rotation D60's, thats the difference. /forums/images/graemlins/wink.gif
