Dana 60 , will 3.55s fit where original 4.88s are now?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Steve_87K5, Nov 14, 2003.
  1. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Am thinking of going with a doubler and taller gears. The original 4.88s are in there now, it's an early '70s SRW full floater I took out of an International 1-ton crew. What are my options as far as taller gears fitting? The carrier is an ARB locker. Thanks
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Are we talking about a front or rear D60? Your sig seems to indicate its a rear...
    Now! If its is a front, there is a split in the carrier, and you can only go as low as 4.56 unless you get the 4:10 and under carrier.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Dana60FF 4:88 ARB. Front: 10bolt w/ARB
    From his profile /forums/images/graemlins/thumb.gif
  4. Steve_87K5
    May 26, 2000
    521
    central NC
    Yes, we're talkin' rear. I know there are some limitations on ratio selection because of carrier design. I'd like to go taller, to 3 point somthing, if I go Doubler. I put the original 4.88s on an ARB 200 000 miles ago.
  5. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    Find a dana 61, my Dana 61 FF has 3.31 gears.....some 61's go even lower into the threes!
    Check for them in Ford 3/4 pick-ups & 8-lug vans.
    Good luck!
    Doc
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Sticking with that housing, you can go up to 3.33 - if you can find them. 3.54 will be the more common "tall" ratio. As already mentioned, you'll need to go to a 4.10-down diff case. That sucks if you have a 4.56-up ARB... and it won't fit in a Dana 61 either /forums/images/graemlins/frown.gif
    Is there a matching 3.54 ratio for the 10-bolt? (Only 3.23, 3.42, and 3.73, IIRC.)
