dana 60
Discussion in 'The Garage' started by 85 blazer, Nov 28, 2004.
  1. 85 blazer
    85 blazer 1/2 ton status
    Feb 12, 2002
    118
    Avoca NY
    Can any 1 tell me what the diameter of the axle shafts on a front dana 60 out of a 79 chevy and spline count?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    35 inner splines, 30 outer. Diamaters I don't know off the top of my head.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Look at Billavistas Dana 60 Bible on PBB: bible
    You should have the early, necked down axles which aren't much larger than the D44 axle shafts.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Older stock Dana 60 35 spline inner axles (particularly pre-1980) neck down from 1.5” at the splines to 1.3" in the middle of the shaft.
    Later Spicer inner axles (1980+) are 1.500” at the splines. 1.562" at the seal surface, and taper up to 1.625” at the largest diameter. The part numbers are the same for the whole run ('77-'91), but around '80, they changed to the bigger shafts. (They were gradually phased in over a few years)
    In order to upgrade an older "neck down" shaft to the larger models, one need only order the standard stock part number or application, and, assuming your supplier doesn't have any really old stock, you should get the larger shafts. This is true for all 3 - Chevy, Dodge, and Ford.
    I know the later 10 bolt shafts were 1 5/16"s thats just over 1.25. So yeah neckdown shafts are about the same size. I don't want to put my High Pinion 60 back together till I get non neckdown shafts, aftermarket or OEM.
  5. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I have pulled down three different 1979 K-30's and all of them had the fat inner axles . Always check to be absolutely sure .
    Tom
