Dana 60
Discussion in 'The Garage' started by 79k20350, Aug 3, 2005.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    So i know theres a bunch of these threads, i did a search but couldnt find anything. I just got my 60 and i know on the pass side of the axle it uses only 1 u bolt, should i use studs or bolts for the other side? im guessing studs are the proper way to go, but bolts are easier. Im not trying to take the easy way out (bolts) but if i can, thats the way id rather do it.
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Either will work fine as long as you have the correct threads. I thought that studs were the way to go until Stephen from ORD sent me a set bolts along with the u-bolt kit in case the studs were too long.
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Thanks!, its just cheaper and a little easier to run bolts.
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I think the factory used bolts didn't they anyway I use bolts and they are fine. They are pretty big so I don't think breakage would be much of a concern
  5. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    factory is bolts grade 5 :wink1:
  6. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    looks like the cucv's used bolts ..atleast several illustrations show them
    From a Cucv manual:
    "All nuts (4) and bolts (5) must be tightened evanly to ensure that springassemblies (1) seat properly.
    Tighten all nuts (4) and bolts (5) in diagonal sequence to 25 Ib.-ft. (34 N.m). Using same diagonal sequence, fully tighten all nuts and bolts to 150 Ib.-ft, (203 N.m).
    Road test truck and check torque of “U” bolt fasteners."
    this only applys to trucks with a D60 front!
  7. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    :dunno: Mine came with 3 u-bolts (6 nuts) and 2 bolts . Don't know where the 4 nuts came from. But my CUCV D60 for sure came with 2 Bolts, not studs.
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The parenthesis indicates the parts with the associated drawing in the book much like part numbers not the quantity of the fasteners.
