Dana 60??
Discussion in 'The Garage' started by wetbackZO, Nov 6, 2006.
  1. wetbackZO
    wetbackZO 1/2 ton status
    Jan 30, 2006
    113
    Las Cruces, NM
    Grandpa is clearing space in his garage and I'm helping by taking what I think is worth something. He gave me these axles but I can't ID them. Is this a dana60? Are there markings somewhere on it to help me ID it?
    I think this other one is a dana44, and it comes w/discs!!
    It's got some weird perches though...
    ...and there's a SM465??
    Thanx in advance for any help...
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    those all look to be D44's the one with the weird perches should be a trailing arm/coil spring ford axle.
  3. gmcburb1965
    gmcburb1965 clever user title
    Oct 29, 2005
    61
    Colorado Springs
  4. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    yeah Im pretty sure those are both 44s. hard to tell from the pics but it looks a little small for a 60. and the other one does look like ford perches. pretty sure thats an sm465 too with what looks like a 205.
  5. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    Pop also gave me a NP203, can't these be hooked together to make a good crawl ratio??
    On the front Ford axle, can I grind/cut those perches off and use it...say, on my Travelall??
    Can these axles handle some big tires, like 38's??
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I wouldnt run anything bigger than a 33 if you planned on wheelin with them, unless you never put a locker in
  7. HoodRich
    HoodRich 1/2 ton status
    Jul 30, 2006
    160
    Kernersville, NC
    The 44 is from a late seventies ford 1/2 ton or bronco, its referred to as a HP Dana 44 with cast wedges, and no you will not find it useful for anything but an application back into a ford. Factory it was coil sprung with radius arms, hope that helps.
  8. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    man...I guess these axles are not as good as I thought...
    but maybe I'll be able to do something w/ the NP 203 and 205...someday...
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yep def hp44. if you run a ford 205 with a 32spline chevy input then you could run it in your chevy is youve got a th400
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Hard to tell from the pics, but that could be a Dana 60 rear. There were a few mixed in with the D44 and 9" rears in the F150s - I believe it came when the Powr-Lok was optioned. Look for a raised "60" in the triangular webbing from the pumpkin to the tubes.
    Nothing wrong with the Ford D44. Better driveshaft angles. Doesn't sound like you know about radius arms... heck, they might be kicking around there too! If dual t-cases is something you are going for, its often not too big a deal to adapt a case that hangs to te opposite side in the process.
    That trans is an SM465, but the t-case looks like it might be a Rockwell. (Top cover plate, and low-drive rear yoke)
  11. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    thanx for the info guys, I'll look for the "60" mark on it, it sure is way bigger than the other one, that's why I thaught it was a d60(I hope so).
  12. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    didnt notice that when I looked at it the first time but after lookin again thats not a 205.
  13. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    The white circle is where (60f) is stamped
  14. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    that's definitely a 465/rockwell t221 combo. these arent too common, only came in some 68's and 69's. then again, the rockwell case isn't the best to begin with....i'd scrap it, sell it to someone doing a resto, but don't use it.
  15. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    i think that 465 will be going in my 'yota...
  16. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    Well I checked that corner where the webbing is and found a big <<60>> on there so I guess it is a d60, woo whooo!!! Lot's of you were wrong, or my pictures are not close enough to the axles...who cares, got me a D60!!!
    Thanx guys, I appreciate all the help...
  17. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    now...how do I find out which years it came on so I can buy some brakes for it?? Did f150's ever come w/this axle?? Maybe f250??
  18. u2slow
    May 9, 2001
    2,217
    BC Canada
  19. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    your 4th and 5th pic looks like a d60, because of the cast rib about an inch back from the diff cover running around the diff a d60 is the only case i've ever seen with that rib....what other diffs have that?
    what is the winch i see in one of the pics?
  20. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    that rear beside the front end looks like it has a pretty big diff....i think its the 1st pic it doesn't have that cast rib like the othe but it still looks pretty big....maybe you have to get a bronco to put those under :)) i think both of those maybe d60's 1 front and 1 rear,i still would like to know what the winch is?
