Dana 60
Discussion in 'The Garage' started by MrArmyAnt, Feb 17, 2007.
  1. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Would a ford rear end dana 60 work on a k5?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Explain what you mean by work.
    If you are asking can you put it under the rear of your K5? Yes, but I'm sure spring pearches, shock tabs, U-joint/driveshaft and some brake modifications will be needed.
  3. MrArmyAnt
    Dec 29, 2004
    662
    That's what I was trying to figure out, what all was involved.
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    You will have to move the spring perches and shock mounts. Why bother with a rear 60 anyway?
