dana 60
Discussion in 'The Garage' started by 69K5, Dec 31, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i was reading four wheeler or petersons anyway. they had the axel guide and i noticed they had a pic of a front dana 60 with the chunk on the drivers side. do yall swap your transfer over or can you change the axel tubes around?
    thanks
    nathan
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    Are you sure it wasn't a ford D60 front? Fords have a driver side frount output.
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    furd D60s have the pumpkin on the "wrong" side compared to dodge/chevy models. Its entirely possible to use a furd d60 in a chevy... you'd just need to get your t-case on the other side. Not sure to many other mods would be necessary. *shrug* I dunno for sure tho...
    j
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    A lot of guys with 88-up chevys use a Ford D60 because the tcase output is on the other side on those.
    You can use a Ford NP205 with a Ford D60 in your Chevy and it will work fine.
    -- Mike
