Dana 60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieRed, Jul 16, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Will the stock (10 bolt) steering arm bolt up to a dana 60. other than ubolts and spring plate what will i need to throw a 60 under the front of my truck. i know new driveshaft yoke too.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    you will need a D60 steering block or X-over steering. 10B steering arm will not work no matter what.
    No front u-joint conversion nneded. They all use a 1310 driveline u-joint. the driveline might need to be lengthened/shortened depending on what else you are doing with your build.
