Dana 60?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudGorilla, Jan 14, 2001.
  1. MudGorilla
    MudGorilla Registered Member
    Jan 14, 2001
    33
    Oregon, USA
    Did all 73-87 1 ton Chevys come with Dana 60's up front? Do they have 35 spline axles?
  2. They did'nt make a 1 ton 4x4 until 78 and ran through 91,all 1 ton 4x4's have d 60 fronts.Not sure on the spline count though.
  3. Rockblazer
    Rockblazer 1/2 ton status
    Feb 18, 2000
    114
    South Dakota
    The answer is yes and no. The inner axle is a 35 spline however the outer was a 31 spline. The dana 60 is identifiable by a couple of ways. The easiest is by looking at right side u-bolt. If it has one u-bolt on the wheel side and 2 bolts directly into the casting, it's a pretty good sign. Dynatrac sells the up grade 35 spline outer stub.
    "You're right... I don't understand that Jeep thing!"
  4. Rockblazer
    Feb 18, 2000
    114
    South Dakota
    Sorry just a correction it is a 30 spline outer not 31 as I previously stated
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    77-91
    Steve
    1990 K5 with stuff
  6. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    To further clarify, only one tons from 1977-1987, then 1988-1991 one ton CREWCABS (4 door) ONLY had the solid axle Dana 60 fronts.
    ken
  7. MudGorilla
    Jan 14, 2001
    33
    Oregon, USA
    Thats what I was looking for, thanks for the info.
