Dana 60's with Alloy Rims
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by a87ss305, Oct 24, 2002.
  1. a87ss305
    a87ss305 Registered Member
    Apr 25, 2001
    50
    Clear Lake, Iowa
    Dana 60\'s with Alloy Rims
    I want to run 16" x 8" alloy rims (probably Eagle's or American Racing brand). Should I be concerned about having problems? I checked American Racing's website fitment guide and it listed a 17" x 8" rim as the recomended wheel for my application, a 1988 GMC K3500. Is this because of the Dana 60's brake caliper? Could a 16" x 8" alloy rim be used if I ground the caliper some like the guys running 15" rims do? Or are the alloys just so much thicker that this size just won't work at all?
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Re: Dana 60\'s with Alloy Rims
    I am running 16x10 AE 589's on a D60 and do not have any problems, however, you won't have enough room to run stick on weights on the inside of the wheels.
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    That's interesting, Fred. I run the same wheels, same D60 and my weights ARE on the inside................. /forums/images/graemlins/confused.gif
  4. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I run 16x10 M/T Classic II wheels on my Dana 60 front end A-OK
  5. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    That is interesting. When I put the 60 on and put on the new wheels, I had a slight "tick, tick...: when the wheel was spun which I traced to the stickon weight hitting the center of the casting on top of the caliper. My grinder made quick work of that.
    Because of a DW issue I recently had my front wheels balanced and the weights used would not clear the caliper, they obviously were alot thicker than what I had previously used.
  6. BurbinOR
    5,829
    Oregon
    Hmmm, maybe a difference in backspacing? I don't know what backspacing I have but can check............... /forums/images/graemlins/confused.gif
    Vewwy interesting............... /forums/images/graemlins/smile.gif
  7. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I don't balance my tires and maybe that is why I don't have problems. My 16x10 M/Ts have 4.25" BS if I remember correctly
