Dana 60's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rockjunkies, Sep 21, 2001.
  1. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Dana 60\'s
    Would a 1980 model 1 ton have the 60 front?
    Keep it simple!
  2. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Re: Dana 60\'s
    Yep it should!
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Re: Dana 60\'s
    to make sure nobody swaped it out you can id it by looking at the pass. side of the axle. it should only have one u-bolt. also on the driver side of the diff it might be marked with a 60. hope this helps
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  4. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    Re: Dana 60\'s
    Do all Dana 60's say 60 on them?
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    Re: Dana 60\'s
    60F i believe
  6. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    Re: Dana 60\'s
    every K-30 1 ton, unless swaped out, had a 60 front from 77-91. All chevy 60's I have seen so far are marked 60F on the differential webbing before the axle tube on the right side of the diff as you are facing the truck head on.
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Dana 60\'s
    All 1 ton straight axle trucks have D60s. They never made a K30 without one.
    I just wanted to clear that up. One day someone on here had asked what a '76 K30 would have under it. The truth is, nothing, because K30s first came out in '77. The last of them was cranked out in the 1991 model year.
    Tim
