Dana 70 disc conversion... Pricing added.
Discussion in 'Vendor Forum' started by cybrfire, Jan 28, 2007.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    $140 with rotors!
    Dana 70 disc brake conversion, Everything you see in the photo x 2!
    This is a weld on kit. However, the bracket is removable after that. This way you can weld the kit on, have no spacers what so ever and still be able to remove the bracket at a later date if need be.
    Both the bracket and weld flange are 3/8" thick steel. The flange is NOT threaded. This way there is no chance in damaging a thread in the flange. If a nut or bolt is to become damaged, replace and go again. Bolts are 1/2"x20tpi grade 8. Nuts are 1/2"x20tpi nyloc grade 8. Loc washers are 1/2" high alloy! Nice stuff.
    This kit will include the rotors, the rotors are not an off the shelf item.
    Just as a side note, If you are concerned about rotor availability, another option would be to source some 14BFF hubs for use on your axle. The hub on some Dana 70's requires a larger center hole on the rotor. This is the reason for a non standard rotor.
    on to the pic!
  2. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Very cool, my bro may need this as he got a dana70hd not to long ago
  3. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    I was about to call for some d70 spring plates...now i may be calling for this as well...lol.
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Will this kit work with dual tires?
  5. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    With the weld on bracket, I assume this is "generic" in that it will work on all D70's, including the D70HD?
    I like the dual caliper setup you prototyped for your towrig, how about producing that or a bracket to utilize D60 front calipers?
    Jimbo
  6. RGV72BLAZER
    Jan 23, 2006
    2,425
    x2......
  7. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    All a vendor would need to do is offer a weld on flange for a D70Hd that has the bolt pattern for a D60 caliper bracket. Space it yourself and use a D60 rotor. :wink1:
  8. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    I'm aware of this, hint, hint, hint..........................................
    Jimbo
    ps (hijack) still thinking 'bout sellin' that cc?
  9. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I was hopin that Kert might pick up on the flange idea. :D
    The cc is gone, she blongs to BulldogK5 now. He and I had talked about it back in Oct so when time came the 1st of this month we worked out a deal. Feels good, I know she got a good home and I don't have to worry about watching some local 17 yr old hack it up into a wheeler. :thumb:
  10. RGV72BLAZER
    Jan 23, 2006
    2,425
    i spoke with Kert earlier today & told me that it'll use 3/4 ton calipers like the 14 bolt setups. not sure on the dually tires thing, but i'm thinking it'll work on my DRW 70HD.......
  11. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I'll buy a couple of sets if they will work on the dually.
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    D60 front calipers? the ones that use the slide in wedge system?
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    OK, I think I'm catching up now. A weld on flange that has the bolt pattern to reuse the d60 caliper bracket and a d60 caliper together. Not necessarily building the bracket that holds the caliper itself.
  14. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Exactly, this is basically what I did with my axle. Here is a pic of mine for the general idea but don't pay too much attention to my housing as it's been narrowed.
  15. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    Heres a couple more pictures of the D-60 front rotor,caliper/bracket rear brake setup.
    This one is on a 14bolt but same,steel donut with correct hole spacing welded to the tube.The old flange can be used to square,clamp and weld the new ring on.
  16. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    So will it work with dually rims and tires?
  17. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Didn't get a chance to check on it today. Thursdays are bad days to get anything done. Steel deliveries, Hardware deliveries, Machine maintenance, shop cleanup day and then some corp. people from one of our suppliers showed up today. That was damn near the whole day.
  18. OnetonCowboy
    OnetonCowboy Registered Member
    Sep 1, 2005
    29
    TX
    Probably will need spacers... I like your pricing and have a HD D70 dually axle that I intend to run Humvee rims on using the stock backspacing so I'm also interested in what you come up with.
  19. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Everything in this thread is weld on so no spacers are required.
  20. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    got these up on the website now!
