Dana 70 disk brake??
Discussion in 'The Garage' started by dcell152, Jun 6, 2005.
  1. dcell152
    dcell152 Registered Member
    Sep 23, 2004
    84
    Nothern Maine
    Is there a kit to convert a Dana 70 to disk brakes? If so will they clear 16" rims? I'm puting it in my 88. My 10 bolt rear spun the pumkin on the tubes, And my front 10 bolt blew to. I'm going with a dana 60 in the front and the 70 in the rear.
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    No standard off the shelf kit that I know of.
    In order to help with more info we will need to know details about what D70 you are planning on using ???
    There are SEVERAL types/styles of D70's and hub arangements with way too many backing plate flanges patterns and positions to lump all into one answer.
    That being said you will most likely be fabbing your own caliper brackets since the aftermarket does not address the D70's with pre-fabbed kits like they do for the 14FF.
    Tom
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    it would probably be cheaper to just get a 14b and go from there. they are cheap, plentiful and the parts are readily available. broken d70 = probably have to order the parts.
  4. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Great Lakes Offroad does. Here is a good write up on disks on a 70. found it linked off pirate a while back....
    CLICKITY
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
  6. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    It can be done.
    We used a few donor axles and did one .
    You will need 10 bolt caliper holders to cut to weld to the D70 tube after you remove the backing plates(cut down to a circle , enlarge to fit tube)
    D44 caliper brackets to match drill and bolt to 10 bolt flanges welded to tubes
    D44 rotors fit the D 70 hubs when you knock off the drums
    Align everything where you want and you will have a disk conversion that seems to work very well
    Just look at some of the kits you can buy , see what they have and get fabbing :grin:
    BTW this was done on a Dodge D70 that we clocked to help pinion angle , just take your time and figure out what you want for an end result
    Happy fabricating
    Note - this is just off the top of my head ,I may have forgot a step :blush:
  7. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Nvrenuf is doing it with dana 60 calipers. :D
