Dana 70 for $200.00?
Discussion in 'The Garage' started by TONYP, Oct 22, 2002.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    just saw this for sale....need to call the guy as he has very little info about it, any help with what i should look for..
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    front or rear ?
  3. TONYP
    Aug 13, 2002
    2,116
    so cal
    the rear...
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Ask what its out of. I didnt think chevy ever used the D70 in any of their light duty trucks (up to 1 ton). You are prolly gonna have to do some fabrication to get it to fit.
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Crwln73 has a Dana 70 full floater with 5.86s in the rear of his truck.I think he said it came out of a Dodge truck.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    GM D70s came only in dually C/K30 trucks (not cab-n-chassis trucks). If it is a GM axle, it is likely far too wide for your needs.
  7. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    you can get d70s out of ford 1 ton duallys-----excat same width as our chevys. just change spring pads. friend has one in his truck right now.
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Same width as a SRW GM C14FF? Or same width as a GM dually D70?
  9. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    gm srw 14ff
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Great, I didn't know that. I thought that's probably what you meant, just wanted to make sure. Beats fooling with a GM D70 if you want more gear/locker options than the C14FF provides...
  11. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    apparently there are 2 different carriers for that dana 70---the one he bought when he orderd a detroit locker it looked just like the 14's detroit----and it even cost about the same.-he's getting ready to slap it under his truck here pretty soon---if he hasn;t done it already ill get some pics w/ some measurements.---he is a machinest(sp?) and he even fabbed up his own disk brake setup--looks prett slick
