dana 70 front end
Discussion in 'OffRoad Design' started by Truckdweld, Mar 4, 2001.
  1. Truckdweld
    Truckdweld Registered Member
    Jan 26, 2001
    26
    Sonoma county, CA
    Stephen, Could you tell me about the dana 70 front end. A bud of mine has a chance to buy one, should he? I have heard they are not as good as they sound but i am interested in your opinion.
    Thanks,
    Ryan
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Dana 70's have a closed knuckle. They are not terribly stronger than a Dana 44. The R&P should be plenty strong, but the weak knuckle ujoint is a MAJOR weak point.
    A Dana 60 would be a much better choice.
    -- Mike
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The above is pretty much what I know about the Dana 70. I don't know what variations there are, but the ones I've heard of are closed knuckle and not worth swapping to. If it's going in a GM truck, it's hard to beat bolting in a standard GM D60. Check it out and compare the parts to a D60. That's about all I know.
    Making the world better, one truck at a time.
    SW-ORD
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Most of them have drum brakes and most 70 frontends came out of Dodges, so there may be a problem bolting it up to a GM.
    Murphy's Laws on Life :
    "Leftover nuts never match leftover bolts." [​IMG]
  5. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    H ow about cutting ends off of a D-60 and putting them on the D-70 with its 10 1/2" ring gear,35spline shafts and disc brakes? The Dodge and Chevy are close enough to make it work,if you think this idea is crazy, I know of someone who did that with a 14bolt FF, dont know the details I just shook my head as I torched the ends off the bare D-60 housing!!!
    RGF
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    the only thing you would gain by going to a d70 center is a bigger ring and pinion, and that's not a real problem with the standard D60 front. sounds like a lot of work for a really minor gain. It's hard to beat the standard recipe, bolt it a GM d60 and go flog it. The reason why people use the 14 bolt tubes on a 60 rear center is to be able to use 35 spl axles, but really, that's a lot of trouble when you could just keep the 14FF and clearance the bottom to be close (within 1/4") to a standard D60.
    SW-ORD
