Dana 70 options
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SuperUnknown, Feb 10, 2002.
  1. SuperUnknown
    SuperUnknown 1/2 ton status
    Feb 8, 2001
    165
    Prince George, British Columbia, Canada
    I just opened up the diff of the dana 70 rear axle I was planning on useing for my project. I found that the ring and pinion gears have several large nicks in them.
    What are my options? Should I re-gear, or just scrap the whole thing and get another axle. Maybe a 60 or 14 bolt.
    It's ok to love your truck.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I would sell the 70 and buy a 14B FF. They are cheep, almost a direct bolt in, and detroits for them are about $200 cheeper than any other axle.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    The decision on wether to keep or scrap really depends on what gear ratio you ultimately want to run. The 14 bolt is limited to a 5.13 while the D70 can take up to a 7.17.
    From a money stand point, you do already own the D70 but, as previously stated, the D70 locker is considerably more expensive. The gear prices are reasonably close.
    I've had a 14 bolt in my truck for about 14 years so I'm not knocking it, it's been a great axle but now I'm planning to swap in a D70 so I can go with more gear.
    80 K10 w/ 468 and 1 ton stuff
    You don't scare me, I got chunks of guy's like you in my stool!
    www.nvrenuf.fws1.com
  4. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well if you are thinking of scrapping it let me know. I wouldn't mind a D70 for the right price. You gain a bit of ground clearence, but loose cash cause you have to cut the perches and shoick mounts to fit. Also setting up the R&amp;P would be costly.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  6. bigredblazer
    bigredblazer 1/2 ton status
    May 10, 2001
    170
    western slope
    In stead of using a Detroit, I would use a ARB, that is another advantage of the 70. Cutting brakes anyone?
    Blazin' Trails ORD Style
