dana 70 or 14 bolt FF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, Aug 28, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    witch is better and/or stornger? and witch is cheper to get or build?
    or sould I go with a duce and a half rockwell
    [​IMG]Go prepared
    I have a Shotgun a Rifle and a 4WD(K5) and Country Boy Can Survive!!!!
  2. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,793
    101
    Paducah, KY
    I posted a question similar to this a few months ago, and the general consensus was that a 14 bolt FF would be much better. Strength wise the 14 has it, but only by a little bit. Size they're practically the same, but cost is where the 14 gets it. You can pick a good 14 up for a couple hundred. Good luck even finding a D70. Hard to come by. There is more stuff available for the 14, and all of it is cheaper. Just an economy thing.
    Oh yeah, and on the Deuce and a half axles, they are tough as hell, but only available in 6.72 ratio. So unless you are planning on running 40" or bigger with an OD tranny, I wouldn't bother. Hope this helps.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Gibson, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Also, the 2 1/2 ton Rockwells use metallurgically-inferior (is that a word?) axle shafts of "only" 1 5/8" diameter. 14 bolt shafts are closer to 1 9/16".
    ken
  4. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    14 bolt is a lot easier to find. I'll sell you a 5 ton rear axle if you want.
  5. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    They are close enough to equal in strength that it's a tie. The detroit locker is cheaper for both because it doesn't replace the carrier in these 2 axles. Then again, neither does a lock-rite, which is a little less expensive than the detroit. Brakes, well TSM makes a fine disc brake kit. The 14-bolt will cost under $200, and almost certainly come with 4.11 gears.
    Go with the 14-bolt.
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  6. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    One of the mags this month just talked about these axles. According to them, the 70 only hangs down 1/4" lower than the 60 and actually uses the same cover as the Dana 60. I still prefer the 14 bolt since parts are so abundant. Any salvage yards will have the parts you need for the 14 bolt.
    Shawn
    87 K5
    few mods
  7. James90
    May 18, 2000
    986
    Rocky Mount NC
    cool
    thanks guys
    how does a dana 60 up frount and a 14 bolt FF in the rear sound
    [​IMG]Go prepared
  8. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    Sounds great James I'll hook you up with a matched set.
    corporate 14 bolt rear locked up with 4.56 gears and a
    front dana 60 with a new carrier and new 4.56 gears all
    for $1,650.00. You would have to pick up shipping. What
    do ya say?
    MUDNUT
  9. James90
    May 18, 2000
    986
    Rocky Mount NC
    that sounds gread just got to find the money some where!
    [​IMG]Go prepared
