dana 70 swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by westtexask5, Oct 26, 2004.
  1. westtexask5
    westtexask5 Registered Member
    Sep 25, 2004
    56
    lubbock,texas
    i have a dana 70 out of a dodge dually. would it be worth using on my k5? /forums/images/graemlins/1zhelp.gif If so whats involved in changing it from drw to srw. Thanx
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nah, too wide.
  3. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    can't you use these to run stock hummer rims...or does it have to be a D70 from a chevy dually? /forums/images/graemlins/dunno.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    if you were going to use hummer rims, i'd say go for it, but you need a D60 front with dually outers to do it.
  5. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    tim is right, the rear axle width would need to be close to the drw 60 which is somewere around 77" wms-wms
  6. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I thought that the chevy hd70 was only too wide. A friend has a dana 70 in a dodge dually that looked like the standard width rear axle /forums/images/graemlins/dunno.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There's definitely going to be some measuring involved, but I'd be willing to bet it's wider than a SRW truck axle.
  8. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    What year Dodge? If pre-94, I bet it will work for you. A 14BFF will be easier, lighter, and cheaper to add locker/gears.
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    guuuuut he 70-60 combo gives you more gear options
  10. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    The 70HD isn't too wide, that's what I have for my Burb.
    It measured out just fine for running the Hummer beadlocks.
  11. ratzila
    Aug 9, 2003
    691
    Mobile,Al
    It's not too wide if you use hummer wheels.If you use the standard wheel it will be too wide. A friend had a hd70 on a dodge with 44" boggers on 15"x14" wheels & 3 1/2" bs and from outside-outside they measured over 104". Not street legal in Alabama /forums/images/graemlins/eek.gif
  12. westtexask5
    Sep 25, 2004
    56
    lubbock,texas
    i measured it, its the same width from baking plate to baking plate as my 10 bolt. I can get new axles and hub assemblies for it to make the track width shorter
  13. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    Since you've already looked into bearing hubs and axles you probably know this but...
    Don't use the brake backing plates when measuring it for vehicle fitment. The backing plates can have a built in offset depending on the brake shoe width (which can vary depending on application). The wheel mounting surface on the bearing hub is the preferred measuring point.
  14. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I am replacing my 14FF with a Dana 70 from a 1975 W350 Dodge Dually and the WMS is real close to a GM Van width SRW 14FF. Do take measurements instead of peoples word - not all Dually axles are the super wide versions.
    Tom
  15. westtexask5
    Sep 25, 2004
    56
    lubbock,texas
    I re-measured from the ends of the axles and it is 5 in wider that a 14ff. plus one of the hub assem. came apart and ruined the axle tube... so idont think ill use it. What about a 14sf if im only going to run 37 or 38 in tires? /forums/images/graemlins/thinking.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    14 bolt SF will be fine. I beat on mine with 38.5 Swampers and it never broke.
    I'd suggest a 14 FF if you can find one cheap though, that's what I run now.
