dana 70 ?
Discussion in 'The Garage' started by cegusman, Nov 15, 2004.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    My friend picked up a dana 60 and dana 70 from a 81 chevy crew cab duelly. Is the dana 70 good for anything, what would we need to do to get it to work in a 78 Blazer.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    It is about the same strength as a 14bff but you have the option of going ALOT lower in gears /forums/images/graemlins/waytogo.gif
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What about width, won't the wheels not stick out far enough? Does anyone make a disk brake bracket for it?
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    The Dana 70HD from a dually is 75" or so wms-wms. hope you like em wide!
  5. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    It depends, was it a pick up or a cab & chassis truck? If it was a pick up then the axle should be a D70HD which it a lot wider than a SRW 14 bolt.
    A combo that is becoming popular is running the dually D60 and the D70HD using unmodified Hummer wheels. I'll be running this set up on my K5. There have been a couple of threads on this, I'll see if I can find them. /forums/images/graemlins/thumb.gif
    As for the disc brackets, no one makes a kit for that axle but it can easily be done. You can use a weld on bracket or you can fab something on your own. I've converted mine to disc using front D60 parts but it required some fab work.
  6. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Boz42 did a write up with some pics HERE /forums/images/graemlins/thumb.gif
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    alot of D70's came with disk brakes from the factory. /forums/images/graemlins/peace.gif
  8. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Not GM dually pick up D70HD's. /forums/images/graemlins/wink.gif I believe the disc brake HD axles are 10 lug.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    weld on or bolt on?
    I took a drawing of a 14ff bracket and had it laser cut as a weld on for my D70
    there is nothing to brake brackets and they are cheap, those ones cost me $40cdn each
  10. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    you are correct, I know where 3 of them are sittting right now
  11. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    I've often wondered if those brackets would work on the truck axle, it would make a nice clean disc conversion. Unfortunately, you'd probably have to pay someone too much for an axle they think is super valuable to get them. /forums/images/graemlins/doah.gif
