dana 70
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by popafink, Dec 31, 2002.
  1. popafink
    popafink Registered Member
    Dec 22, 2002
    14
    Great MOAB UTAH
    has anyone played with a dana 70 front axle i have one and want to know if it is strong it is closed knukle
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I had one too. Was from a early 70's Dodge. Closed-knuckle as well. 4.10 gears. Just sold it a couple of weeks ago.
    It sure looked strong! Never ran it so I don't know for sure. It was missing the locking hubs. The guy I sold it to was going to do some machining to make Dana 50 (Ford TTB) stuff fit - which is essentially Dana 60 outers.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    They are plenty strong, but I think the rebuild parts cost a lot, and a closed knuckle is harder to rebuild than an open.
    If they are built right they are indestructible, but weigh even more than a D60 so...
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The problem with a closed knuckle Dana70 is.....that it is closed knuckle. They put dana44 sized axleshaft ujoints in there - seriously.
    The R&P will be unbreakabkle - D70 is equivalent to a 14 bolt FF, but the knuckles are crap.
    There are open knuckle D70 frotn axles out there - the only one I have ever seenw as in a picture in a Four Wheeler. I don't know what it came out of, but it was going under the front of a 4x4 motorhome.
    Sorry, but the bottom line is that it is heavier than a D44, only stronger in the R&P (which is not USUALLY where they break) and the cost a lot of under pumpkin real estate.
    -- Mike
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    no improvement over a 60 for our purposes.
    the above post using TTB 50 outers is a great idea for your 70f, these are common and not on the 'super desireable' list yet
    u2slo should probably not have let this outta the bag LOL
    try and size the tubes to fit the 35 spline 60f inners
  6. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    there are two of the closed knuckle 70's out there one with a 44 joint the other is the same as the 60. I called wagoneer machine to see about having the tubes cut and open knuckles grafted on them, they told me the inner seal causes a large problem and the cost would be cheaper in the long run to run a 60. H0ope this helps
