Dana axle identification
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by biltntboght, Feb 6, 2002.
  1. biltntboght
    biltntboght Registered Member
    Jan 9, 2002
    37
    Medina,Ohio
    I am looking for a Dana 60 front axle. How can I tell the difference between a Dana 44 and Dana 60? I know the 60 is bigger but there must be a easy way to tell them apart.
    Todd
  2. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    go to the the technical section at the top of the page and go down to the axle identification section and it should tell you all the info you need to know.
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The first, unmistakeable way that I figure it out is to look for balljoints. If it has balljoints, it's not a Dana 60.
    Tim
  4. Glock Girl
    Glock Girl Registered Member
    Jan 15, 2002
    54
    NY
    Look at the steering arm. A 44 will have 3 bolts a 60 4
    Shelby
    88 K5
  5. biltntboght
    Jan 9, 2002
    37
    Medina,Ohio
    Thanks Shelby good tip Thats why I asked I knew somebody would have an easy way to know which is which.
    As you travel on thru life whatever be your goal keep you eye upon the donut not upon the hole
  6. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    my dana 60 says 60 right next to the cover plate on the front.
    1986 GMC Jimmy 6" springs 3" body, 38/15.5/15 Swampers, 14-bolt FF rear, Dana 60 front, 1991 front-end.
