dana is that you?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dmoney, Jan 26, 2007.
  1. dmoney
    dmoney 1/2 ton status
    Jan 21, 2007
    119
    Silverhill, Al.
    how do I know a dana when I see one?
  2. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Search this forum.
    Google search.
    Yahoo!! search.
    etc.
    etc.
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    If it isn't a 10 or 14 bolt, its probally a dana!
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    60? 44? front or rear?
    big difference....
  5. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    I have a 90 burb with stock 1\2 ton and I am looking toward the future, wondering what to do as upgrade as far as axels
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Its a topic argued about in the garage all of the time. Much of what people will tell you depends on your build plans and how you are going to use the truck.
  7. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    dailydriver with very min offroad time, just dont want to tear up every time I go in the mud...
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Whats the biggest tire you plan on running?
  9. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    wanted 38 but I dont want to get into gearing and such so maybe 36 or37
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    For a DD, a 3/4 ton swap would be fine.. 38's will start to get questionable on a balljoint axle imo.. a 3/4 swap is a 14ff and 10bolt, in the 8 lug variety... Tho you could go 14sf to keep it all 6 lug, but that brings up gearing....
    And I'll assume you have an auto in there... 700r4... So, if thats the case, your gonna strongly need to consider a gear change when upping your tire size to a 36, 37... you'll burn that tranny up..
    Most 3/4 axles you'll find will be 4:10's, which will be ok... 4:56 would be better... here's a gear calc to help you figure out your rpm's...
    http://www.florida4x4.com/tech/gearcalc.php
  11. bandit4369
    bandit4369 Registered Member
    Mar 20, 2006
    82
    Nw. Pa.
  12. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    yea i am not going to run in overdrive with 36s, so I am just figureing out what way I want to go... Thanks for all your help guys
  13. bandit4369
    Mar 20, 2006
    82
    Nw. Pa.
    They also have a tire, gear ratio, rpm at 65 mph chart there too.
  14. dmoney
    Jan 21, 2007
    119
    Silverhill, Al.
    Thanks bandit, I am new to this stuff so any info helps
  15. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Just a note on 3/4 ton stuff it doesn't really matter whether you have a 10 bolt front or a Dana 44 front. They are very close in strength
  16. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
