Dana Powr-Lok
Discussion in 'The Garage' started by tomseviltwin, Sep 4, 2005.
  1. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Is this diff any good on a Dana 70?
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    traction wise I don't think so but they don't have the reputation of exploding like a gov-lok
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    If you are in need of a fully locking diff than the P/L will disapoint you BUT if you want a true to life limited slip type diff than the P/L is the most aggressive clutch type diff offered for Dana axles.
    A lot of folks that complain about P/L's are either at full hard core truck status or have been using a P/L that is already wore out and needs rebuilding. They are very good and STRONG units !
    Tom
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I've got one for a D70HD up on eBay right now ending tonight around 9:00 and it is rebuilt with brand spanking new clutches and plates. :deal: :deal: :deal: :waytogo:
  5. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Linky???
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    the powr-loc in my dana 60 is 35 yrs old and still going strong. They can be rebuilt and additional clutches can be added to tighten it up. This is per the dana60/70 powr-loc manual I have. They reccomend 3 clutches per side for front applications and 5 clutches per side for rear applications.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Well, not quite.
    On the D70, each side of the side gears require 3 clutches and 2 plates. Should have 6 clutches and 4 plates in the whole shebang. :waytogo:
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    As I understand it, the main advantage of the Power Lock over the Trac Loc can be seen in the "apart" view of Wes's ebay link. It has FOUR spider gears, while the Trac Loc only has 2.
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The extra 2 spiders are a minor detail. The major difference is how aggressive it is. The Trac-lock relies only on the spreading force created from spiders turning to compress the clutches. The Powr-lock has 'ramps' for the crosspins to wedge against and apply more force to the cutches.
    The Powr-lock is a very heavy duty and aggressive limited slip. It is revered by many as the ultimate traction device to use in a front axle application.
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Spoken like a guy that has never picked broken spiders gears out of a diff housing... ;)
  12. u2slow
    May 9, 2001
    2,217
    BC Canada
    :haha: Nice try... I'm the dude on the far left ;)
    http://www.elcamauto.com/form2.php
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Looks to me like you stand around and talk on the phone... :wink1: :wink1: :wink1: :wink1:
