Dana Trac-Lok, gimme your thoughts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudzer, Aug 3, 2000.
  1. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I found a Dana Trac-Lok locally for around $100. Is this a decent unit and will it hold up to 35" tires and some crawling. I know they are rebuildable which makes this a good option and they would probably be more drivable on trails. Does anybody have a picture of this unit? Is it a gear type or clutch type locker? Is it even considered a locker or LSD?
    Thanks,
    Neil
    Mudzer 1978/91 K5
    <font color=blue>www.mudzer.coloradoK5.com</font color=blue>
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Don't waste your money. Rebuilt or new they're good for 5-10,000 miles, after that you got an open diff. Save some more money and get something effective.
    ken
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    While a Trac-Lok is better than an open diff, they are generally considered one of the less effective limited slips (or least aggressive) on the market. They were designed for smooth street operation and little extra traction in wet grass or snow. I have seen a newer Dodge Ram with 15,000 miles and a factory Trac-Lok that would deliver absolutely no power to the ground when one of the full floating axle shafts was removed (same as having one tire in the air).
    But again, if it's a choice between either the Trac-Lok or an open diff it will help.
  4. ggallin13
    ggallin13 1/2 ton status
    Mar 31, 2000
    199
    Northern Nevada
    I would save up until you can get a Detroit and get it done right the first time. I am firmly in the "build something once" camp, so take it for what it's worth!
