Dana44 front versus 10 bolt
Discussion in 'The Garage' started by 88jimmy4x4, Nov 8, 2003.
  1. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Im thinking of buying a Dana44 from a member here (really good deal) but I would like to know what are the advantages of a Dana44 versus a 10 bolt for the front?
    Instant advantages for me is the fact its setup with the gear ratio I need, but other than that....why is it better?
    Also, how had of an install will it be to swap these?, will it be a plug-n-play sorta deal? brake lines, u-bolts, spring pad locations...etc?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is no advantage of a D44 over a 10 bolt front. Both use the same size u joint and that's the weakest spot.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Easy swap....Only real advantages I can think of for a 44 over a 10b is more gear ratios to choose from and more diffs to pick from.
    Pull the cover and save yourself and the seller some headache. I JUST came back from pulling the cover off the one I had bought to find half the ring gear teeth missing. Will my swap ever occur????
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    The only advantage a Dana 44 has over a 10 bolt is the fact that the differential case is made of nodular iron instead of gray cast iron. On a Dana 44 it is a toss-up as to which will happen first: case breaks or 3/8" thick tube bends. On a 10 bolt the case always breaks first and relatively easily.
    Other than that, the shafts are made of the same 1040 steel and the universals are the same. The knuckles out are identical so there's no difference there.
    The rest is pretty much identical too. Ring gear and pinion shaft diameters are very similar and so is the hypoid mesh. The carrier of a Dana 44 is supposed to be stronger but I haven't seen any proof either way.
    Dana 44 parts are starting to get pretty rare. 10 bolt parts were around from 76-78 (I've seen a 10 bolt ring gear stamped October 1976) until 91.
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    /forums/images/graemlins/shocked.gifI can't believe you didn't check out the diff before you bought it! I have bought 2 different sets of used axles and checked both front and rear diffs every time. It would be very risky and costly to not check the most important and expensive part of an axle. Bummer about the teeth man. /forums/images/graemlins/frown.gif Goes to show how important pulling the cover before you hand over the cash is.
  6. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Thanks guys, the diffs from a CK5 member so I trust him.
    Guess I will have to think about this one /forums/images/graemlins/thinking.gif
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    If it has the gears you want, go for it!!! Otherwise the axles are pretty similar and you DO NOT want to invest in gears and install on either axle. My belief to these axles is to put as little money into them as possible or down the road you will be kickin yourself.
  8. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Ah very true indeed....I am lucky the guy is going to make it right. What caused the failure is the bolts holding the Power Lock together starting backing out allowing the diff to wobble. The whole thing only has one run on it.
    True you shouldn't really trust anyone. I think of this guy as a CK5 member (although he isn't) and both ways there is a very good chance that discrepencies will be dealt with in a fair fashion.
    As usual, buyer beware......
  9. OffRoadOhio
    OffRoadOhio Registered Member
    Mar 5, 2003
    87
    Lancaster Ohio
    I heard soemthing about 10bolts snapping becuase fo the spring setup? What is that all about and is it true?
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    MISF had the same thing happen to his front Powrlok. Killed the R&P also. If you're gonna run that diff, do yourself a favor. Drill the bolts for safety wire, Torque all to spec, degrease and use Red Locktite plus the safety wire. Might use a AN flat washer on each bolt, do not use a lock washer of any sort.
  11. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Thanks for that information....I am definately gonna try something different.
