Dana44 leaking; is there a seal?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spincast375, Sep 12, 2004.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    I just bougth this 84 Blazer. In changing the fluids, I saw the Dana 44 up front was packed with sand. Cleaned it out, replaced gasket, new fluid. Major leak. At first I thought it was at the bottom of the cover. But see it is at the rear, by the driveshaft/ujoints. Is there a seal here? I don not see one in any of my repair books.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There is a pinion seal there.
  3. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    yup what harley said,
    also is your front axel stock? the one that originally came in the truck? if so it "should" be a 10-bolt
    read a manual on changing the pinion seal, if you dont think it is for you dont try it as there as if you canscrew it up by not tourqing thing down enough or too much.
    maybe inlist the help of a local member?
    -good luck /forums/images/graemlins/thumb.gif
  4. spincast375
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    Thanks for the heads up. It's important to know one's limitations.
