dana60/ leaf spring center pin question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Nov 25, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    im almost done w/ the whole axle swap/lift and i have run into yet another problem, the center pin for the passenger side is a bit too big for the hole in dana60. wat do i do? take the axle off and make the hole bigger? just say f--- it and bolt it on? the thing goes in somewhat just not completely. please help cause the driver side is all bolted up and i dont wanna take the thing back off again.
    thanks,
    phill
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I just encounter the same problem with my recent lift. I took my Dremel tool and used a cylinderical shaped grinding wheel and ground the inside of the hole in the 60 and the pin itself just slightly. I ground carefully and they fit like a glove. It took less than a minuet on each side.
    Derf00
  3. shupach
    Dec 28, 2000
    648
    Dallas, TX
    thanks derf, ur a god
    phill
