Dana60: puller for side bearings? Home-made spreader?
Discussion in 'The Garage' started by Steve_87K5, Jul 6, 2003.
  1. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    1. Is the Posi-Lok puller sold by Sears strong enough to remove D60 carrier bearings? Sears sells 2 sizes. 4 & 6 ton IIRC.
    2.Case spreader: anyone have a drawing so I can make one?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    No drawing, but the spreaders are fairly simple in concept.
    It's a pair of bars (say 1/2" x 2-3") a little longer than the diff casting is tall, with a pin that fits into the drilled holes on the casting at each mid-point.
    The top or bottom ends of the bars are seperated by another bar held on with a single bolt at each end. The opposite end of the bars have what amounts to a turn-buckle seperating them. Fit the pins into the holes and turn the turn-buckle to lengthen it.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You may not need the spreader. Mine was fine with small pry bar and rubber mallet. If you use a spreader, be careful. I've heard more than once of a housing damaged by over-spreading...
  4. Steve_87K5
    May 26, 2000
    521
    central NC
    I built this Dana60 10 yrs ago and I put it together w/o a
    spreader. High miles on it now. I suspect the carrier preload is light and
    I am thinking of adding maybe a .005 on ea side. May have trouble getting it back in.
