Dana60 Question... PLEASE HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Sep 29, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK So I got a good buddy with a junkyard and he has so many stinking front ends and whatnot... what would a dana60 be under??? What kind of truck would it be on... What year??? what do I need off of it???
    PLEASE HELP!!!
  2. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    assuming it's for your blazer, you need to look for 77-91 k-30 chevy trucks that are single wheel. All, unless swapped out will have the sought after 60. You will also need to snag the ubolts and plates.
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  3. reddog64
    Nov 9, 2000
    3,325
    Thanks!!!
  4. reddog64
    Nov 9, 2000
    3,325
    there not on anything else??? just chevy/gmc???
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    They are on Dodges and Fords but for a direct swap you will need one from a GM.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    And remember to pull 2 of them, don't even thing of the cost just ship it out west and I'll see that it gets a good home.
    <font color=red>Defeat is not being knocked down, it's not getting back up</font color=red> <font color=black>Stand Strong, Stand United</font color=black>
    <font color=orange> 1955 Willy's</font color=orange>
  7. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    a dodge one can be made to work
    they are narrower
    the spring mount cl is about 1" wider on the dodge
    i have been thinking a set of offset bushings might get you closer
    the dodge steering arm is a good piece to get if your chev is lifted at all
    w 10"springs i used a retapered dodge arm, 2" drop pitman, and 2.75" block to put the steering linkage as good as it can be.
