Dana60 question>>>>
Discussion in 'The Garage' started by Burt4x4, Jun 5, 2002.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Anyone have the outside diameter measurement of a Dana60's axel tube? Do they differ from front axel to rear axel? Or are all D60 axel tubes the same outer diameter axel tube?
  2. Burt4x4
    6,854
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have measured mine at 3 1/4" outside diameter. /forums/images/icons/wink.gif
  4. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    I pretty sure a front D60 has 3 1/2" tubes. I'll check after work and repost if no one has answered definite.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    No because the 14FF has 3 3/8" tubes and the D60 are slightly smaller than the 14FF. /forums/images/icons/wink.gif
  6. Burt4x4
    6,854
    Front axel or Rear? Or are they the same anyway?
    Thanks!
  7. Burt4x4
    6,854
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    On GM axles:
    D60 front, 3 1/4" tubes.
    14FF rear, 3 3/8" tubes.
  9. Burt4x4
    6,854
    Cool...so any idea if a rear D60 has the same size? I would imagine they would be the same for production reasons?
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Rear D60's on Ford, Dodge and Chevy vehicles are all in different configurations.
    I have seen D60 tubes anywhere from 2 1/2" diameter tubes to 3 1/2" diameters. All were different on every vehicle.
    A good general idea to use for the D60 tube size would be to recognize the older vehicles to use the smaller diameter tubes. For example: 1965 half ton Ford trucks were available with the 5 lug pattern D60 rears. These tubes were very small, something like 2 3/4" diameter tubes.
    So, there is no real set size of D60 tube. Everything is different, just like all the different variations of ratios and locker choices. /forums/images/icons/wink.gif
