Dana60 rear conversion ujoint and ubolt and size question
Discussion in 'The Garage' started by jjlaughner, Dec 7, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Whats the conversion ujoint for 10bolt to Dana60 rear?
    Also what size u-bolts and plates do I need for the dana60 rear?
    OH is the nose on the 60 longer than the 10bolt (for driveshaft length reasons), whats the WMS/WMS width, and finally will the spring perches need moved?
    /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Mine has the 42.5" spring perches, no moving. (shock mounts needed moved though)
    Axle tube dia is 3", spring plates should work.
    Not sure on the U joint or the length of the snout. I can get these for you though.
    Is it from a GM, Furd, or what?
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I thinks its from a early to mid 80's GM
    Glad to hear most of the stuff will go back with no problems /forums/images/graemlins/thumb.gif
    What about WMS-to-WMS? Wider than a 10bolt?
    Anyone have a conversion ujoint or spring plate mount comment?
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    AFAIK, GM quit using Dana 60 rears at the end of the '72 model year. /forums/images/graemlins/thinking.gif
    Furd & Dudge continued to use them for a long time after that. /forums/images/graemlins/deal.gif
    The GM D60 rears have the same axle tube(3") and axle shaft(1.31, 30 spline) diameter as the 10(some) & 12 bolt.
    IIRC, the D60 rear that I had, that SUBFAN now has, had a WMS spacing of 67". /forums/images/graemlins/thumb.gif
  5. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    WMS equals 66"....I am going to run spacers, if I ever get the thing installed....
    The spring plates from the 10b will work for ya....
    Very good chance it has a Power Lock installed....Let me know if you need an open carrier with 4.10's attached /forums/images/graemlins/thumb.gif
  6. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    The Furd housing I had was the same WMS, 3" tubes also....The spring perches and shock mounts will need to be moved.
    An interesting thing about 'that' Furd housing, was the fact that the bearings appeared to be larger on the spindle end. The axles are not interchangeable, as the bolt circle on the Furd is a bit larger. The lengths were very close. Same spline counts.
    Anything else?
