dana60 with pitted kingpin
Discussion in 'The Garage' started by rubbinz raczn, Nov 15, 2004.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    when taking apart my dana60 one of the upper kingpins showed some pitting. no rust present so from a previous rebuild. question is,the pitting isn't real bad but it is there. i would replace the kingpin but they need 600ft lbs torque so getting the thing off would be a bitch as well as not having a wrench even close to those specs by the way, the axle is not in truck so leverage would be a problem also!
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    check the kingpin rebuild article. You can see what Billa used. I wouldn't run pitted kingpins. THey will likely eat at the bushings and do who knows what to it.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    take axle to a truckshop that has large impact gun
    no leverage required
