Dana70 Frontend
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Truckdweld, Mar 4, 2001.
  1. Truckdweld
    Truckdweld Registered Member
    Jan 26, 2001
    26
    Sonoma county, CA
    I would like some info on the dana 70 front end. Are they as strong as you would think and are they worth buying and building up. Thanks
    Ryan
  2. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    Not worth buying and building up IMHO. They almost always have drum brakes, no lockouts, 10.5" ring gear, and they are usually found in a dodge. Most if not all i've ever seen are also closed-knuckle-yuck! The only advantage to them is that they sometimes came with 35 spline 1.5" outter stub shafts. But you can upgrade a D60 to the 35 spline models and you will have a nearly indestructable assembly.
    Squash
    <A target="_blank" HREF=http://www.trailrunners4x4.org/users/realsquash>http://www.trailrunners4x4.org/users/realsquash</A>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Unless you dont mind spending a pretty penny, have Dynatrac custom build you one. I called them once, and they said they CAN build a D70 front axle!!! This would be the ticket to bulletproofness if the D60 is not enough (which it is). You could get the custom D70 in open knuckle, 35 spline inner and outers, any ratio, etc. Give Dynatrac a call for a quote. Bet it will run around $4000.00. (shudder!)
  4. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    As long as we are talking custom axles, could a 14b front axle be built? I know they are big, how much bigger than a d60? I am just asking because I don't know, not because I plan on doing it(unless it makes since to and is possible).
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have never heard of this before!!! Now this is an idea for you to tell the guys at Dynatrac about!!!
