Danas??
Discussion in 'The Garage' started by MR.4x4, Aug 5, 2002.
  1. MR.4x4
    MR.4x4 Registered Member
    Jul 17, 2002
    66
    Hi, i have a Blazer 74 with 350 and 35 tires, and im going to change my axles, wat axles do you recomend me??
    44 Dana or 60 Dana??
    I think dana 44 is strong enough, but if i want to increase my tire size??
    Thanks for your help
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> A beefed up (full case carrier, cr-mo shafts, good hubs, quality ball joints, etc) 44 is at it's limit with about 37" tires. I know because I broke mine repeatedly with 38s. </font color>
  3. MR.4x4
    Jul 17, 2002
    66
    Hey shaggy, wat did you Broke??
    Do you make hard rock crawling??
    I´ve seen some trucks with Dana 44 and 40´´ boggers /forums/images/icons/shocked.gif
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I play in everything, but do not do any really extreme rock crawling (although that will change with the D60 in there /forums/images/icons/grin.gif ). I broke numerous axleshafts (including 1 Warn inner and 1 Warn stub), a bunch of u-joints, and 2 ring gears. </font color>
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If you're talking about the front it came w/ a D44. If you're talking about the rear the 12B it came w/ has a bigger ring gear. If you want to upgrade D60/FF14B combo is the wat to go. What sive tires do you want run? Are you going to change ratios? Adding a locker?
