dang carb question
Discussion in 'The Garage' started by jacked_86chevyk10, Aug 2, 2004.
  1. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    alright, time for a new carb...edelbrock probably...but heres the question...which size do i get? i have edel. intake, dynomax headers, hopefully soon new cam and all the inner works.. but which size (cfm) will give me the most of power, tourque, responce and most importantly MPG, but im mostly concerned with the responce on the low end and mpg...so any suggestions will help...thanks
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    650 cfm. I may not be a fan of Edelcrap, but I would think 650 cfm would be good for a small block assuming thats what ya got. BTW, I ran a 650 cfm Holley on a majorly built 383 stroker in a 73 Camaro, and it was pleanty.
  3. jacked_86chevyk10
    Feb 4, 2004
    42
    SNELLVILLE, GA
    thanks man, if all yall guys dont like edelbrock who else should i go for, demon? or what? thanks
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]Most of the guys and gals around here do like Edelcrap, I'm one of the few who doesn't. In all honesty, a Q-jet is hard too beat for off roading.
  5. jacked_86chevyk10
    Feb 4, 2004
    42
    SNELLVILLE, GA
    to be honest with you, this is a pavement pounder truck...1/2 tons with big meats....(basically my truck to drive everyday to college, i have a k5 mudder but thats not the point) this carb is gonna be for the road truck...sbc 350 i jus want the best combo of power and mpg...thanks
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]In that case, Demon carb, Road Demon 625 cfm. Clicky That's what I would choose.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Then get a Quadrajet from Jet , I-5 , Edelbrock , The Carb Shop . Smaller primaries for economy , big secondaries for when you those BIG street meats to puke out your axles and pinion bearings . Makes my 305 feel like more than it is /forums/images/graemlins/waytogo.gif
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I think he has a squarebore intake manifold.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well he could get the adapter for square to spread , which is a little taller and works like a spacer anyway . Or if its a performer , it would have both patterns drilled /forums/images/graemlins/k5.gif
  10. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I second the Demon. Awesome street performance carb.
  11. diesel4me
    Jul 24, 2003
    17,540
    925
    Massachussetts
    I dont know much about the new carbs like demons,I have mostly had carter AFB's and the edlebrock clones they now make--if you want the best mileage,smaller CFM carbs are available,like the 390 CFM Holley carb,and edlebrock and carter make a 500 CFM version of their 4 barrel carbs--and the smaller size barrels keep the velocity of the fuel moving more quickly,improves low end tourque,and avoids bogging.But if you have a big cam,higher than stock compression,and headers,you may have to use a bigger jetting,or even a bigger carb to avoid it running too lean,lean is good for mileage but you cant let it go too lean or valves can burn and pistons can melt.I ran a 450 CFM on a 74 454 years ago,one of those "Economaster"carbs--I had nothing else hanging around the shop,so I threw it on just to get me to work till I could buy a better carb--but I was suprised how much better it ran than it did with a 600 Holley that was on fire most of its life--I got 15mpg with it,and the 4 barrel would put you back in the seat.Everyone said I'd burn the valves,but I ran it back and forth to NH and VT many times,no real problems,it would ping in the mountains if you ran regular,but nothing premium gas didnt quiet.I think a lot of engines are over-carburated,even from the factory(at least the CFM of the 4 barells)Sometimes LESS is more! /forums/images/graemlins/crazy.gif
