Dang starter keeps doing this
Discussion in '1982-Present GM Diesel' started by 76_Cheyenne, May 3, 2004.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    I made a post before about my starter not engaging. Its a brand new starter since Jan. and I was told by GM that i needed a new one because it did the same thing. I turn the key and it just clicks. I've checked every connection i can find 5 times over, they are all good. I'll have to sit and turn the key like 50 times till it finally engages. Sometimes it starts first time sometimes i just leave it for a few hours after it wouldn't start, then the first time i try it, it turns over! Its embarrasing! Even took to to GM again and the couldn't get it to not start! just my luck! any idea why the starter binds up like this? Is it bad?
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Check the shims- You gotta make sure the starter is engaging at the proper angle. Make sure the starter gear is making full contact.
  3. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I think it's in your ignition switch ?Not enough juice to pull the solenoid back . Next tim eit does it by bypass the switch and try jumping it from the starter /forums/images/graemlins/dunno.gif
  4. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    And then after you do that, make it a push botton start
  5. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I agree jump the starter. You can get a cheap starter jogger switch at most auto parts stores. Just connect the leads to the starter and run it up into the cab. Each time you want to start the truck, just move the ignition switch to run , and hit the button. It will tell you whether it is a starter issue or an ign switch / wiring issue...
  6. 76_Cheyenne
    Jan 23, 2002
    285
    Missoula, Montana
    Ok, ill give that a try next time it does it. SO you guys are just saying hook up jumper cables directly to the starter from the battery?
  7. 6.2 man
    636
    Curtis , WA
    No what they are saying is run a wire off the battery to a toggle switch then run a wire off the toggle to the solenoid /forums/images/graemlins/peace.gif
