DANGNABBITTT!!!! WTH is up this THIS!?! (q-Jet problems)
Discussion in 'The Garage' started by zakk, Sep 19, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Ok, here are the specs:
    Brand-new GM motor with 475 miles on it.
    engine goodies include:
    Summit Headers
    Uber-Spark wires
    Curved HEI
    Well tuned q-jet
    edlebrock Performer manifold
    fliped air cleaner
    Brand new tranny with 475 miles on it.
    w/ mild shift kit
    POS K5 of mine, a gazillion miles on it. One ton, X-over steering with 20 miles on it. 39.5's that are "balanced" only in theory.
    I keep spitting vaccum port caps. particularly (remember, i cannot speel!) the rear 3/8 one facing the trans tunnel.
    I have a Kragen Q-jet that i have had ZERO problems with after we tuned it. I have no choke, no nada. and it is getting to be a pain in my phat arse to crawl under there every day to replace these caps.
    it does backfire a bit when cold, could that be it? can i crazy glue the damn cap on??? or is this a tell-tale sign that my engine is gonna go :boom: on me?
    /forums/images/icons/smirk.gif
    *signed*
    the fat kid that hates vaccum stuff.
  2. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    so waz the problem? you forgots to tie wrap them vac plugs on? that must be some backfire you gots there. mebbe time you look see if the caps are really soft. if so then need replace em good ones that hold on better.
    Also so did that backfire flip you air cleaner lid or was that an intentional modification? /forums/images/icons/wink.gif /forums/images/icons/grin.gif /forums/images/icons/tongue.gif
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Whats your timing setup? Rate, amount, initial, vac advance amount, etc. I remember when I put a questionable MSD box on my shortbox and it blew off every line on the carb! I guess that answered the questions.
  4. Grim-Reaper
    7,385
    Atlanta
    Once it's running, even with loose caps, the only way it could blow the caps off is if your getting positive intake pressure. You have some sort of problem in the motor. Hopefully just a timming issue. Check your distributor and make sure it's not hangin advaced. Also check base line timming.
    Where are you pulling vac for your vac advance on the distributor? Facing the carb on the truck the correct port is on the front right (driverside) just above the base plate.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the distributor is HEI, so there is no vaccum advance. I am running the soft caps, but i am squeezing on a size smaller, still blowing them out.
    So i have either positive vaccum, or could the backfiring be doing it?
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    ...and make sure it's not hangin advaced. Also check base line timming.
    please advise as to what "hanging advance" is. Also, the engine is at 12* BTC, IIRC. It ran like a champ until this cap problem started...
  7. dubl_t
    dubl_t 1/2 ton status
    Jun 8, 2002
    141
    Oregon
    don't hei's have a vac adv?
  8. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    the earlier models of hei are vaccum advanced while later models are electronically controled. i don't know what years that started tho. i'm sure someone will chime in tho. later.
    jacob
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    mine is electric
  10. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I don't know the answer, but bring it by the house tonight for the BBQ and ask Scott to check the timing for total advance and see if it's somehow "sticking"? (I don't have a GOOD timing light...the one with the adjuster knob, so if you have one, bring it.)
    Anything short of a "demonic possession" in your engine, and Scott can figure it out! /forums/images/icons/cool.gif
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    it won't even make it. i would love to bring it over and have the guys gimme their opinions on what is wrong, but it died going to the mailbox yesterday! /forums/images/icons/shocked.gif
  12. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    So you have a curved hei that is electronically controlled by the computer? Never heard of it.
    I presume this has been running well before???
    *IF* the HEI checks out, as a non-computer controlled HEI, you must be getting some CRAPPY gas mileage on the freeway.
    IF it is computer controlled, you NEED to make sure the HEI is on the right timing tooth. Even if it is set correctly. You CAN get backfires.
    Are you sure your spark plugs are setup in the correct order? I have messed up my #5 and #7 too many times to count!
    Tight valves?
    Lean Carb?
    Good luck.
  13. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the HEI was "worked" by a buddy. that is all i know. i traded $10 and a six pack for it. it ran great in the old motor, no reason to think it is bad now.
    my truck doesn't have TBI or anything...so computer controled it isn't. all the wires are right. I do not think it is a tooth off, but that is atleast a suggestion.
  14. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    hmmm Tooth off would really only apply to computer controlled.
    Get a timing light and verify it advances the timing as the rpms go up.
    Good luck.
  15. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    - It does backfire a bit when cold, could that be it?
    - I have a Kragen Q-jet that i have had ZERO problems with after we tuned it. I have no choke, no nada
    On a cold start, the carb can deliver a A/F ratio as rich as 1 to 1. What actualy makes it to the cyls is far leaner than what is flowing from the carb tho'. Partly due to the in-activity of the air in a cold engine and low engine speeds (low air speed vilosity). These conditions cause the fuel to puddle and collect on the intake manifold walls and floors. The problem is even more pronounced if the stock air cleaner heat-riser is not used.
    The stock choke system on a Carb will increase the booster signal by as much as three fold or more, richening the mixture as needed to compensate for the cold climate conditions.
    A lean engine may back-fire through the carb. (increaseing intake manifold pressure above ambiant air pressure)
    A rich engine may back-fire through the exhaust.
  16. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I also axed the stove pipe, so my problem may be as simple as hooking the choke back up? i drove it one day, gave it 5 minutes to warm up, and didn't blow a cap. Maybe i just need the choke back on it....
  17. Grim-Reaper
    7,385
    Atlanta
    The mechanical advance under the rotor. Make sure it's not hanging.
  18. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    ah...another thing to check /forums/images/icons/grin.gif
    thnaks grim!
  19. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Possibly, are there anyother drivability problems that could be related to this?
    If it is a A/F ratio problem when cold.
    You could just keep your big-fat foot off the gas pedal till it reaches opperating temps.
    Or richen up-the idle mix a bit.
    Thats all well and good now, but when it gets colder outside, you may have problems getting it to start.
