Danna 44 6 to 8 lug conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, May 25, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    What is involved in this conversion? How much could I expect to pay for the parts? Would the parts from a factory 8 lug 10 bolt work? Thanks!
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    All 6 and 8 lug parts are interchangable from the D44 and 10B from the knuckles outward. The only thing you need to watch out for are the spindles. Make sure if you take off the rotors off one of the fronts, take the spindle off with it. '77 and newer spindles are all the same, but the '76 and older use a smaller bearing for the spindles. You need the correct matching spindles to make the larger bearing rotors work properly. Even the '76 and older stuff can be used on the '77 and newer as long as you reuse the '76 spindle if the rotor came off of it. Sound confusing?
    When In Doubt, Whip It Out!
  3. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Confusing... yes and no.. I'll just make sure they are both from a 77 and later truck... which I think they are but I'll double check.
    89 K5 Silverado
