Darn bolt need help/ideas
Discussion in 'The Garage' started by DUKE, Jun 6, 2002.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    OKay got up to do the lift install, everything going smooth get the front done, move to the rear and im stuck. Everything came off the rear passenger side except the front eyebolt of the spring. I broke a decent size craftsmen wrench and two sockets. I heated itwith propane torch and lots of pb stuff. besides the bolt being in a tuff place i can not get it to move. I had a 2.5 foot breaker bar with my hi lift handle on it no go. What else can i try before i take it someware to have it cut? i spent most all day on this one bolt, need ideas before morning. also the front shocks top mounts i cant get out, and the steering arm is a pita to get off.
  2. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    I've taken off plenty of bolts, nuts, rivets, etc. with a good old angle grinder. It's not terribly quick but it'll do the job. You can get a fairly good one for about $40-50 too. They're pretty useful to have around.
  3. GMMANIAC
    GMMANIAC Registered Member
    May 1, 2002
    53
    San Antonio, Tx.
    One thing you might try if you have access to an air compressor and an air hammer, is use a flat headed tool in the air hammer on the head of the spring bolt. This has worked for me at my shop. The vibration from the impact will sometimes allow the two parts to seperate from each other. It's worth a try before you have to go postal on it.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    mine took about 2 hours of hammering to get out appiece.punch and BFH was what i used along with soaking it for four days with penitrating oil.every time i got a chance id spray it some more till i was ready to take it out and put in the new springs
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    A Acetylene Torch will burn Hotter than Propane. If You can Borrow one from a Freind or Whoever, this will Burn the Rust Loose.
  6. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I have been fighting the same thing all week. I made a press out of a C clamp, a piece of pipe, and a couple of pieces of flat bar. The press is similar to, and could be used as, a u joint press. I had three of the bolts seized on me, and w/ a lot of persistance, heavy amounts of WD-40, and an impact wrench, they finally cooperated. Just keep after them. If you need more details, let me know.
    John
  7. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Is the nut stuck on the bolt or is the bolt stuck in the bushing?
    John
  8. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    lets just say both, as in niether will budge. I think i will just take it to a weld shop and have em cut em with whatever they use. Good news is i got the stearing arm off about 2 hours with a sledge and two beers at 10 am and it was done. I got a saws all and will be taking it to the body tomorrow if i can get to the weld shop today.
  9. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    good idea, ill go postal on it =)
  10. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    made quick work of mine with a grinder and a big 6 to 7 inch thin cutoff blade. it fit nicely in between the hanger and the spring. it took the bolt out in less than 30 seconds, but be careful its quite dangerous.
