Darn Electrical leak.... help!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pookster, May 1, 2002.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Well, about 4 months ago, I started getting dead batteries after a week of not driving... It's fine after 2 days or so, but... I dont know where there is current still being drawn! I thought it was the amp, so I disconnected that. Nothing is plugged ino the cigarette lighter. All the lights are off.
    My finger is pointing at the stereo....
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Doesn't matter if nothing is plugged into the cigarette lighter....is there a wire connected to the cigarette lighter still?! It tends to short out there....
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Disconnect the positive lead, connect a light bulb to the battery and the positive lead. Does it light?
    If it lights, you have a leak. Start pulling fuses until it goes out. If all fuses are pulled and it is still lit, then you got problems!
  4. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    What TopOff said is good advice, but I have always been told to disconnect the negative battery cable and run the test light from the negative post to the cable. I think this is a little safer than working with the positive lead. Anyway, pull the fuses one by one and when the light goes out, you've found the short, UNLESS....
    The short is in the alternator itself. Old or worn alternators can start to ground internally, causing the scenario that you describe.
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Thanks guy. Will try that out. Acutally, thats a brand new alternator in there, the problem was acutally happening before the replacement....
    Acutally, the battery didnt die all the way when I last checked. I gotta check if the complete drain down wore out the battery, because last time I checked the trickle charger had diffulculties reaching the "fully charged" indicator.
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I have also seen where a seat belt buzzer had shorted out and drained the battery even though the buzzer may not be buzzing.
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    An electrical 'leak'.
    Sorry, had to smile at that one. I think I will call them leaks from now on.
    I like that.
    Ken H.
  8. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    leak, its a technical term. /forums/images/icons/smile.gif
    Technically, it is one electrons flowing out somewhere. /forums/images/icons/smile.gif
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    A buddy of mine had an Electrical "Leak" in his K 2500. Like yours it took a few days to drain his battery. Drove him nuts trying to find it. It turned out to be his glove box light switch was stuck on all the time. The switch worked if you pushed it in with your finger but the glove box wouldn't activate it all the way. You couldn't see it unless you looked under his dash at night and "Saw the light'
  10. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I was gonna suggest the same thing Thunder. I had a customer that dead centered a telephone pole w/ a Jeep Cherokee, he wasnt wearing a belt and tore that dash up pretty bad. I replaced most of the lower section of the dash pieces, as well as the whole front end, and a good amount of the structure, but never thot to check the switch. I was tracing wires ALL over the front end thinking it was something up there from the wreck. We looked for days to find that!
  11. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Simple enough to look underneath and see where the puddle of electrons is located. Heehee!
  12. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You are such a dork /forums/images/icons/laugh.gif! Haha, j/k. Thats pretty funny, I like it.
