darn sqeeky noise!!! ahhhhhhhhhhhhh
Discussion in 'The Garage' started by supersize75k5, Sep 8, 2004.
  1. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    well I am ready to loose my sanity..or put a radio back in the blazer....
    heres the story...
    I jump in the truck in the am after truck has been sitting for a few hours, truck sounds fine, after a miles or two she is squeeling like hell...
    I replaced both the serp and v-belt since they were at least 5 years old...still sqeeling.
    undid the serp belt and spun the water pump...no squeek
    the alternator bearing is my next hope /forums/images/graemlins/dunno.gif but having lights on or off makes no difference on the noise.
    It is constand and always present while motor is on and while I shut it off.
    ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
  2. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Check for coolant leak. It will leak on the belt and belt will make noise forever. Took me and GM a year to figure it out. Went through 2 water pumps, 1 alternator, 3 tensioners and 2 idler pulley trying to figure it out.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    You could try a stethescope
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Tighten the belts , seroiusly tighten them . Mine will do that on the alternator belt unless I use a bar and really move the alternator and tighten the belt up . It will not wear out quicker either , they just need to be tighter . To prove it , spray some belt dressing on it ( or pour coke and let dry ), if it goes away , then comes back later and pisses you off , belt is too loose /forums/images/graemlins/k5.gif
