dash brake light wont go off
Discussion in 'The Garage' started by shaun89, Jul 13, 2006.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i just put in a 14bff and bled the brakes, i didnt have enough time to get new hard line on there so i was driving my old line for a couple days and it was fine, now i replaced the hard lines from the divider to the drums and now my dash brake light wont go off. the e brake isnt hooked up yet, could that be it?:confused: o ya and 89, no abs
    ps. i searched...didnt find much
  2. 92k1500CO
    92k1500CO Registered Member
    Oct 2, 2005
    40
    Colorado
    dash brake light
    The dash brake light in our cars has two purposes - to tell us when the e-brake is on AND to tell us if fluid is low. Sometimes when you bleed out stuff, the prop valve can get stuck, or the sensor for the brake fluid can get junk in it, hence, it turns on the brake light. Time to start taking stuff apart! :doah:
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    There is a shuttle valve in the splitter. If you don't hold the button in when you bleed it or drive with one system empty the valve goes to one end and switches the light on.
    You can re-centre the switch usually by just putting really heavy pressure on the brake pedal (engine off). If it doesn't, turn ign on but don't syart truck, stand on the pedal and get someone to open the bleed valve that you've been working on. (put a bit of hose on it or something) Once the pedal has gone all the way down close the valve and release the pedal, the light should've gone out.
  4. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Did you check to make sure the pedal is fully released? being no cables hooked up it may not be up all the way.:D
  5. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    damn, i got a lot of things to try,i guess ill go start, thanks a lot guys:bow:
  6. goldwing2000
    goldwing2000 Guest
    Almost but not quite. It's second purpose is to tell when you when you have a large pressure differential between the front and rear brake systems. Sometimes this is caused by low fluid level but not always.
