Dash coating
Discussion in 'The Garage' started by SUB-ZERO, Jan 13, 2006.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Has anybody coated there cracked-up dash pad with something?New ones are insanely expensive.I was thinking of having mine sprayed with line-x.
  2. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    When I bought my truck it had a dash cover already on it. The PO tried to install it w/o removing the Dash Pad First and well it didnt seat right. So I took it off cleaned off the silicoln and used liquid nails to glue it back down.
    But if you do this do the front section first then the rear later. And use clamps to hold the Pad on the Dash while it dries.
  3. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Liquid Nails?!That thing will never come off!!
  4. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    Exactly:D
    i mean the dash covering that was on it. Did I do something Wrong:confused: :D
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    hes taking about the plastic covers that are repro that go over your pad, not the actual pads
  6. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I' talking about spraying the whole thing pad,cover and all.Of course I would remove it first.Line-x says if I remove it and leave it with them they could spray it when they have a bed or something big to do and would only charge me $50 for the dash pad and $50 for my 4 door panels to spray black with uv inhibitor.The repro covers alone are $100 and god knows what a set of 4 new door panels would cost!Plus its non-skid so I can put stuff on it without it slidin' off.Whada ya think?Any drawbacks I'm not thinkin' of?
  7. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    From what your talking about That sounds like a pretty good idea. If you do it let me know how the door panels turn out.
